Britannia
Monty Stubble
Britannia
Hello,
Looking for a Britannia Motor, the flat twin two stroke. Why? A group of us are re-creating the Mk 8 cockle (4 man canoe) so are keen to get hold of the power unit. Non-runners or projects - we want 'em all to get at least one runner to function.
We are well on with the build but have drawn a blank for engines outside of museums.
Best prices paid (and a free ride in the finished canoe).
Re: Britannia
I do know of some one, but I think he has all good runners.
But with no location its hard to help you.
Monty Stubble
Re: Britannia
My location is the Lancashire/Yorkshire border but am willing to travel far and wide to secure an engine.
In any case a runner would save us lots of time. i'll post a photo of the project on here later.
I even have some old motors for swops if this helps sweeten the deal.
Monty
Monty
Monty Stubble
Re: Britannia
Here's what we're making - a 4 man self propelled canoe (by Britannia Power)...and here's how far we've got for our modern one. Next job to skin with plywood.
Re: Britannia
Monty
You prepared to travel to Perth Australia?
Between my mate and I we have a few. They are ALL functional and depending on the year have original decals.
Shipping to the UK would be about $AU 740.00.
How much do you want to pay upfront for something original and useable and what year/model should we quote on?
Monty Stubble
Re: Britannia
So you want a Middy!
I will enquire locally.
You realise of course that the pic you last posted is missing the "Port and Seal" assembly. Hope you made your canooooooo strong enough to suport and retain that Mate.
Interesting project by the way.
Speak soon.
Speak soon.
Re: Britannia
Sorry I can't help here Monty, but I like the project, please keep us posted with the progress. Good luck
Re: Britannia
Might as well watch things Brit' as they come up everynow and again down under..............
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
I am still working on your cause.
this looks 50's to me Bruce, charles
Monty Stubble
Re: Britannia
Hooray - We have a Middy. Collected it yesterday and it seems complete. It's slightly different to our hearts desire in that it's from an airborne lifeboat (slightly different exhaust set up)but we can work around that.
Sadly it's locked up solid and doesn't want to free off.
Also having trouble getting the top off the flywheel.
Don't suppose anyone has a scan of a manual do they?
Nothing simple is there?
C
C
Re: Britannia
Post pics of flywheel and cylinders. Gearbox and hull fixing adapter.
I may have data sheets depending or advice as to what you have.
Well Done eh?
You lot are very determined and brave in this endevour.
Well Done eh?
Monty Stubble
Re: Britannia
Really struggling to get the engine freed off. Everything else is apart and in pretty good shape but can't get the cylinders off. The inside of the cylinders seems ok when looked at with a endoscope so the rings must be seized. Probably with 50 year old oil if the rest of the engine is anything to go by. Got the heads as far as the end of the studs (but not quite off). In any case want to resist twisting the cylinders for fear of distorting the con rods. i can see the alloy pistons through the exhaust port but the rings are above this.
So far:
Liberal application of penetrating oil.
Heated with oxy and percussion with a copper hammer
Soaking in diesel for a fortnight
Putting on a set of screw pullers.
Next idea is to make up a 22mm hydraulic fitting into the spark plug hole then use a portapack pump to force off the cylinders.
As you can see - getting desperate now.
Any thoughts?????
So far:
Any thoughts?????
Re: Britannia
As long as rings/pistons above exhaust ports fill cylinders completely with engine oil, with no air spaces replace spark plug, refix cylinders, mark flywheel position & gently warm both cylinders over the course of 10 mins with blow lamp up to circa 100 c.
Mark on flywheel will show if pistons move, failing that you will get some hot oil down the side of the pistons/rings, if pistons move then rock backwards & forwards until free, after draining oil.
Monty Stubble
Re: Britannia
Here's the little waister, undergoing a spot of Yorkshire Traction (an in joke for Bus Lovers - which I am not!)
