Raggy Old Seagull for Spares or Restoration,
I have an old seagull (century I think) in my Garage Serial No CFCL 833W7. Got it with my boat about 5 years ago but have never used it. Started it once and it ran OK but idled badly. Pumped water OK though. It has a pull starter bolted to the top. Also a clutch. The bottom inch of the skeg has broken off so the engine rests on the blades if propped against a wall. Also the alloy strip with the teeth for holding the engine in the raised position has parted. Still got the strip though I doubt it could be welded back on successfully. It could be restored or stripped for parts. Any offer considered - I am located in Cumbria, England.
