New project - what do you think...?
Posted: Tue Oct 05, 2010 11:54 pm
by PeterW
Evening all !!
Now I've cleared the garage I've now got chance to build a small (10ft) boat to use with the Forty plus that I restored last year.
Its been designed in carene, and this is the freeship output so far
Hull needs a skeg as its going to be dragged up a few shingle beaches where I plan to use it
Comments please !!!
Pete
Re: New project - what do you think...?
Posted: Wed Oct 06, 2010 8:11 am
Not the correct nautical speak, looks a bit fat up the sharp end.
Also for that waterline I would think you will need loads of ballast.
Stick it on a diet and make it.
Posted: Wed Oct 06, 2010 9:10 am
by PeterW
Thanks H-A
The waterline that is shown is the one freeship has put in and I have no idea where it gets the information from in relation to calculating that !!
I'll have a play with bow widths etc and then get on with building it ! It's designed to use 3 sheets of ply with a double skinned transom for strength.
Pete
Posted: Wed Oct 06, 2010 12:04 pm
by PeterW
Ok...
Mk6 Hull with a few changes made, looks more 'boaty' at the front now ! :D
Its also shorter by 350mm, making it a shade over 10ft, which is ideal as its got to fit on the Land Rover !
Pete
