wanted large long shaft seagull aluminium exhaust [with the 2 small holes]no dents please 22" lg
also standard clutch lever with ball on end
also clutch rod 31 1/4 "
also water pipe 23 1/4 "
long shaft exhaust,clutch lever,water pipe,clutch rod
- Niander101
Re: long shaft exhaust,clutch lever,water pipe,clutch rod
Is it not easier to buy a whole engine as you need the powerhead as well?
- Niander101
probably im looking!
- Niander101
Im sorted for this now also!
