Cocktail Class Wooden Boat Racing Association
http://www.ccwbra.com/index.html
Look like they might go just with a seagull.
Videos look good.
http://www.clcboats.com/shop/boats/powe ... racer.html
Worth looking at these next pictures
http://www.clcboats.com/media_gallery/s ... e=1&next=1
Roll on the good weather, this must be one to build.
spiderg
Re: Cocktail Class Wooden Boat Racing Association
Post by spiderg »
H-A, what do you think the spec on building this would be, i.e. how many sheets, glass etc?
Looks quite like a wee yellow thing that pops up in pictures here every so often.
Looks fun though.
Gerard :evil:
Rob Ripley
Post by Rob Ripley »
Perhaps the design could benefit from a cav plate to stop the porpoising.
For a 1939 design it's quite pretty, but very small, looks very over built, & needs the pilot position moved forward by almost a foot, as I'm a light weight i'd look like a figurehead driving that & with all those bulkheads & ribs I don't think I could carry it.
Here's a picture to show how many ribs & bulkheads the yellow one needed.
spiderg
Post by spiderg »
Good points Charles. It does look a neat wee toy though. Like yourself I'm on the lower scale of the weights and I would be steering with my pencil whilst I leant right forward. Could it be modernised a bit? I really like it. The question I ask myself, what's more fit for purpose, this one or H-A's masterpieces???
Gerard
The picture on the net of the frames of this boat, are drawn to scale.
I am tempted to build one, but much lighter than the Yanks version.
spiderg
Post by spiderg »
Would you care to expand on your thinking H-A?
Gerard.
Charles will pm you tomorrow and let you know when I'm at home
spiderg wrote:Would you care to expand on your thinking H-A?
Gerard.
:wink:
I don't see the point of building a hull that requires 50+ lbs of ballast right up in the bow, to permit you to use the steering in the coventional manner.
I think it's safe to say there are some major flaws in this design.
And they want more than $1000 for the complete kit.
Charles uk wrote:I don't see the point of building a hull that requires 50+ lbs of ballast right up in the bow, to permit you to use the steering in the coventional manner.
Plans £25, build with WBP and epoxy £150.
Boats are being built and raced in 33 states and 7 countries, can't be all bad.
This class of racing boat has areas that can be improved, but they are restricted by class rules to keep the speed down.
I think I will send off for some plans so that I can keep in class rules. The boat must have a minimum weight of 72lbs, to meet US regs, not sure I will do that.
Buzzook
Post by Buzzook »
Weight 72lb...32kg....
Nuff said...
I've carried one of Raoul's boats and I guarantee it didn't weigh 20kg....
I was very involved with the build of Microgull 1, when it was first painted it weighted 39.4 lbs & if I remember right it was 11 ft 3" long.
It's been repaired several times in the last 8 years, it slid off the trailer 1 time & got towed down the road by the bow line, that took some glass & filler, because I had to fix it, & it's been painted several times, a coat of paint on a boat that big must weigh 1 lb.
I'd guess about 45 lb now.
skyetoyman
Post by skyetoyman »
I just wonder how these young ladies manage to steer in that position. One can't imagine where the tiller arm is going
Terry that's where the expression "does my bum look big in this?" came from.
skyetoyman
I did almost say "I could see spiderg in one of those" but swiftly changed my mind
