Silver Century Plus noise when in gear
Posted: Sat May 12, 2012 10:18 pm
by Shawn
I have a '68 or '69 Silver Century Plus longshaft. I haven't run it in a few years.
I put in a 25:1 jet and when I went to tank test it it fired right up and was running fine. However, when I put it in gear I am getting a loud whirring that doesn't sound right and I don't think it was doing it last time I ran it.
I drained the lower end and I had the thick tan sludge of 140 weight emulsion that has been in there. I took the lower unit cover off to clean it all out. The gears look a little corroded but I have never had it open before so I don't know if that is how they have always been.
With the plug removed and the main gear out when I spin the flywheel I don't hear any sort of rubbing in the driveshaft.
Any thoughts on things to check. I can post pictures of the gears if that helps.
Thanks,
Shawn
Re: Silver Century Plus noise when in gear
Posted: Sat May 12, 2012 10:41 pm
by Taspiper
The only thing I can think of is that the gears are running without enough clearance. The only way this may of changed is if you took the cover off for cleaning before you noticed the noise and altered some clearances by changing the gasket?
Maybe the rubber grit seal has swollen causing the gears to run tighter by pushing the prop shaft forward?
Posted: Sat May 12, 2012 11:30 pm
by Shawn
Hi Rolf,
I didn't take the cover off until I heard the noise.
Checking it out again I realized the pinion gear isn't fixed in place vertically. With one finger I can push it up into the housing far enough that it isn't engaging the ring gear at all.
I can't imagine that being normal?
Shawn
Posted: Sun May 13, 2012 1:25 am
by electrosys
You shouldn't be able to do that with the pinion ... sounds as if the pinion sleeve bearing has come loose.
Posted: Sun May 13, 2012 2:45 am
by Taspiper
Yes and maybe the pinion has become seized in the bush. Time to pull appart....
