Little Forty LS20105
winter
Post by winter »
Goodmorning,
I read somewhere that the availability of spares for the Little Forty as above (LS20105) is very poor.
Is that true? Because someone offers one which looks good, but I don't want to buy a problem.
Attached some pictures
Re: Little Forty LS20105
I don't think they are anymore a problem than any other seagull, parts are not so easy to find, but that can be said about some of the older models.
See it running before you buy.
winter
Post by winter »
Keith,
It runs but not very smoothly. Needs cleanup of Carb and spark etc.
That's no problem for me.
Do you think this is an attractive one?
And is the colour of the tank original?
I would rather have it black.
Evert
Attractive, well I wouldn't go that far. :oops:
No the tank would be painted, the decals are available if you wish to change it. Also throttle cable maybe a little long, but its still a tidy little motor.
Its a big looking prop for a little motor, but I prefer the FV models with the round tanks anyway.
winter
Post by winter »
Thanks. Well, about 60,= pounds is not to much.
I saw a FV and liked it very much but it was not very complete. Missing parts of the carb and some non-original parts.
Niander101
Post by Niander101 »
Ive seen much worse than that it even has good chrome on the drive shaft and exhaust also the ignition cover plate is very good...what more do you need?
for the tank fill the dents and spray it...easy!
winter
Post by winter »
Think you are right, but tonight I am getting pictures of other Forties, however a bit younger then this one.
So, I may be in a position to choose the best and the cheapest. As a real Dutch I am always looking for the best prince/value.
Niander101
Check out the chrome everything else you can change
