http://www.ebay.co.uk/itm/British-Seagu ... 3a7fc9b518
Including the posted question and answer,
Q: hi,its a common diagnostic error thinking frost damage,its the shear amount of rust in the cylinder jacket expanding out spliting the water jacket its jam packed with rust 29-Mar-13
A: Hi I am interested in your theory and fully accept that the waterways are packed with rust. However surely it was the water that had been trapped by the rust that expanded when frozen and cracked the block? Has anyone done any experiments to demonstrate the force caused by iron turning into rust in a confined space? Is it greater than water changing phase at around 0 degrees? Regards
So i beg the question, how many of you true seagullers will be bidding?
