Is my impeller facing the right way?
Posted: Fri Jul 26, 2013 8:41 am
by frankystein
Hi, I've decided to give the engine a minor overhall before I take it out - assuming that I get it going!
This is not a great photo but you should be able to see the blade angles for the impeller - are they facing the right way?
http://i818.photobucket.com/albums/zz10 ... l/0033.jpg
Re: I my impeller facing the right way?
Posted: Fri Jul 26, 2013 10:50 am
Looks good.
The upper ring has all the markings on it and should face up that picture view.
"TOP" should be there aye.
Posted: Fri Jul 26, 2013 12:00 pm
by frankystein
My engine is pumping water but not very well. I don't get a steady pencil thick stream of water from the outlet - it splutters out and is quite hot. Here's what I've tried:
1. Propeller removed.
2. I'm revving quite quickly (but not too fast because without a propeller there's no load on the engine). I'm aware that seagulls don't pump at low revs, but the engine is spinning fast enough.
3. Varied the depth of water in the dustbin (exhaust is 2-4 inches below surface).
4. Moved position of impeller up and down the drive shaft (lowest point is a few mm above the gasket because I don't want to rip the material).
5. Pumped water from a garden hose from outlet in the top - water passes through to the bottom very well.
6. Removed the gearbox and connected a host directly to the bottom of the copper water feed - water passes through the top outlet (pencil thick and steady).
Anyone got any ideas?
Re: Is my impeller facing the right way?
Posted: Sun Jul 28, 2013 12:51 am
by Vic
It's the wrong way up surely?
Picture below shows correct way!
The disc should be uppermost and upto 1/16" clearance between the rotor and joint plate is correct
Posted: Sun Jul 28, 2013 9:54 am
YES
Posted: Sun Jul 28, 2013 8:07 pm
by Vic
Collector Inspector wrote:YES
But the OP's photo shows it the opposite way to the diagram in my post above.
So, "NO it is not facing the right way".
Posted: Mon Jul 29, 2013 8:28 am
by skyetoyman
I think you will find CI is agreeing with your last statement ie "YES - it is facing the wrong way.
Posted: Mon Jul 29, 2013 10:26 am
by frankystein
Problem solved - my impeller was upside down with the 'teeth' facing the wrong way. I now have a steady stream of pencil thick water from the outlet. The engine is ready for its sea trials this Thursday. Thanks for the help.
Re:Right or wrong ???
Posted: Mon Jul 29, 2013 11:57 am
by Vic
skyetoyman wrote:I think you will find CI is agreeing with your last statement ie "YES - it is facing the wrong way.
His post is is headed "Is my impeller facing the right way?"
Anyway the OP has now now fitted it correctly and all is well again.
