Can prop be changed to improve performance?
robhc1000
Post by robhc1000 »
I have a 1970 approx 102 (wc 385 r6) and it has a 3 blade prop on it, can prop be changed to improve motor performance?
1650bullet
Re: Can prop be changed to improve performance?
Post by 1650bullet »
A prop change could increase your boats speed by only a knot or 2. Show us the prop you got now. There are 2 different 2 blade props for seagulls that I know of.
robhc1000
Post by robhc1000 »
Sorry, my prop is 3 blade not 2, post edited...
phil
Post by phil »
Go to Help section see post titled "Prop"
robhc1000
Post by robhc1000 »
Many thanks, had a read through and it looks like im after a 4 blade hydro one.
Rex NZ
Post by Rex NZ »
When you compute some performance numbers on seagull props, it emerges that they 'slip' badly
Increasing the drive face area lessens this loss
Basically you need more blades
kevinemery
Post by kevinemery »
What does that mean in English.
Not sure I agree Rex, let's take the example of a model 80 Century plus with a 4 blade weed free prop.
Prop diameter & pitch, 11" x 10"
Gearbox ratio, 4 : 1
Total blade area in square inches 45.52
Hull speed per 1000 engine revs with zero prop slip, 2.08 knots
Hull speed at 4000 revs 8.32 knots
Many of us have been close to that with a small light hull, what would you define as bad slip, 20% plus?
That would give you 6.6 knots.
Interesting but ........................
Rex NZ
Post by Rex NZ »
All props must slip in order to achieve drive
Ships setup well slip at about 5%, poorer ones at about 10%. Numbers like 30% - 50% slip could use a bit of work (common seagull range)
This is where the sword cuts both ways; (Theory vs Practice)
You can reduce a prop slip by increasing the working drive face (this will be somewhat less than the actual drive face, maybe half). Simplest to increase the number of blades,
however,
The reduced slip may drop the engine rpm below an optimal power level (of say 4000rpm)
so
To get a low slip prop to work in your favour you may have to drop the gearing ratio (a practical difficulty) or reduce the prop pitch (another practical difficulty)
As a more interesting side issue, slippage (in particular excessive slip) also leads to the creation of a wasteful vortex from the tip. :wink:
You can address this with a vortex de-generator (VG). You see these in nature as the 'fingers' on hawk wing tips. Also seen on better aircraft (Noting our best aircraft are fairly lame compared to hawks)
Here you can see the dynamic with your eye. At the prop tips the sudden pressure drop in the vortex causes the helical vapour trail
Isn't slip almost directly dependant on the load?
Rex NZ
Post by Rex NZ »
Charles UK
Yes, there is a co-relation between load & slip.
However, (in theory at least) if you let too much slip occur,
then,
you can end up wasting alot of energy
The barge pusher designs show they are made for heavy/ugly loads
Low gear ratios & big diameter props with lots of blades
water bug
Post by water bug »
I have noticed that in the USA Outboard racing props ( in the 1950's - 60's ) had razor thin blades, and cupped. The edges being hammered forward slightly for some performance advantage. How is blade thin -ness edge sharpness , and cupping affect performance or slip? Seagull stock props are rather thick bladed. I AM certainly no expert, just interested. WB
Rex NZ
Post by Rex NZ »
Waterbug
Thin blades drag less & waste less energy. Water is very viscous at speed. Maybe think of it like wet clay
The cupping of the trailing edge is a good observation. Basically cupping an ordinary prop 'fools' the water into thinking the blade is longer (read greater area) than an non-cupped blade. Effectively increases the drive face a little
therefore
less slip with a cupped blade
however
The sword cuts both ways. The cupping costs you drag. So there's a cost/benefit battle that needs to be evaluated
The racing props you saw have a different dynamic again. They are not ordinary sub surface props. These were probably 'surface piercing' props. The blades actually break the surface of the water without ventilation being an issue. With surface piercing you can run the prop so high that the hub is clear of the water, which reduces drag.
however
Again the sword cuts both ways. Surface piercing is a dynamic suited to planing hulls, plus there's issues with prop walk
