Piston rings for a Seabee Minor
Post your wanted adds here
robhc1000
Post by robhc1000 »
Im after 2 piston rings for a seabee minor and my normal supplier does not have any so wondered if anyone on here had any spare they wanted to sell?
Re: Piston rings for a Seabee Minor
What is the bore in mm
What is the depth of the piston ringland in mm
What is the height of the piston ringland in mm
Do not round off to a whole mm.
I get rings made if not available from my local sources.
robhc1000
Post by robhc1000 »
Collector Inspector wrote:What is the bore in mm
Thank you, will measure up, do you know approx cost to have them made?
Cost.............. no at this time. Not expensive but need measurements first. It is the thickness/depth that determines a ring price when something not off the shelf is required.
Try local to you if any available first.
If you can not find rings, my price will be at cost plus postage to you or anybody on S.O.S.
Need dimensions as above as stated.
robhc1000
Post by robhc1000 »
Thanks Bruce, a uk supplier has had some made up, a set costs £23.50 posted.
One problem solved.
Price about right!
Pics when doing work aye?
robhc1000
Post by robhc1000 »
Collector Inspector wrote:Price about right!
Yes, will post pictures of work In progress, I cleaned points and got a spark yesterday :D
