Australia prop washers and split pins
Posted: Wed Jul 30, 2014 10:52 am
by THCL500J8
Hi Wondering if any of the Australians on the list know any were in OZ that we can get prop washers and split pins.
Went to change the week prop spring on a mates LLS and found the old tin missing. So any ideas?
Has anyone used those steel spring clips with any success?
Thanks.
Re: Australia prop washers and split pins
Posted: Wed Jul 30, 2014 11:23 am
by chris
I just use whatever washer and split pin that fits, at the moment I am using stainless as that is what I have laying around
Posted: Wed Jul 30, 2014 7:32 pm
steel spring clips (we call em "R CLIPS" ) work great. tried and tested.
makes changing the drive spring much easier and quicker with minimal tools.
Posted: Wed Jul 30, 2014 9:52 pm
by phil
I was thinking about this recently and ended up getting some 1/2 " i.d. SS lock washers, the type that are split. My plan is to bend them a little so the ends match and weld them back together, they are just the right thickness, use them with SS cotter pins which are easy enough to get here.
Posted: Thu Jul 31, 2014 4:58 am
by AusAnzani
When I purchased my LLS, it had an Sping Clip (R Clip) already fitted. Worked well for the previous owner i guess!
Posted: Sat Aug 02, 2014 6:24 pm
by 1charan
I use a stainless steel washer that is meant for 12 mm thread. Nothing special about it.
Posted: Sat Aug 02, 2014 9:48 pm
by phil
How thick is it?
