Opening a 102 gearbox
Posted: Sat Jan 31, 2015 12:24 pm
by Shearwater
I'm still working on the restauration of my 102. Now I'm facing a dilemma. I can't get the end cap off. I would like to see if everything is ok inside. I tried a bit of hammering on the prop shaft but that doesn't work. Peeking through the oil filling hole shows no problems, everything is running smooth and I flushed it a while ago to get all old oil etc out. What do you think: should I leave it as it is and fill it with new oil, ore should I try harder to get the end cap off. And how? Harder hammering, heating?
Re: Opening a 102 gearbox
Posted: Sat Jan 31, 2015 1:29 pm
If all feels OK then do not get too stressed.
Posted: Sat Jan 31, 2015 3:44 pm
It's probably a good idea to remove it and clean all the sludge out, as well as getting the gears nice and clean. That said I ve often found a cleaned box to be more prone to leakage
The end cap will have stuck in place with a combination of corrosion and possibly old gasket goo. Apply some gentle heat all around and tap the lugs gently with a plastic or wooden mallet to allow the end cap to rotate. Do it in both directions and it should soon loosen. Once off give the whole thing a really good clean and you are good to go.
I've got a SD box to look at at some point that needs the pinion replacing.Thats going to be a right job I suspect.
Posted: Sun Feb 01, 2015 11:01 am
Yep, if needs pulling apart relax.
Lots of help here aye!
Some pics would be cool...................We All Love Pics!
Posted: Mon Feb 02, 2015 11:21 pm
Drain the contents of the gearbox first.
Remove the brass collar on the drive shaft and the 2 or 3 screws on the front cover.
Find something to place in the slot where the drive spring sits, heat the front cover and outer edge of the gear case and with a rubber or wooden mallet, hit quite hard on the end of the shaft.
Always works for me.
