British Anzani Minor help needed
Re: British Anzani Minor help needed
Got a pic of the part? you could still send one and I could give it a go!
AusAnzani wrote:Some great work going on here.
B, maybe we should have sent the Seasprite Spark plug cover over to Nudge for reproduction. I reckon we would have had a box load of them by now.
Still trying at this end. Christmas closures etc, not helping though!
Yes S
Then again a few more kilometers to what can be termed as a "forren land of clouds , treasure, and mystery" ARR
Kinda keeps it in the "Family" Aye.
All the best XMAS and New Year.
A bit of an update!
Showing how the mixer body is hacked and drilled!
fitting the inner copper tube
Checking the fit
Making sure the cowl still fits!
Ended up casting a chock cup... Bit tricky at only 1mm thick!
All the parts!
Checking the fit
All the parts!
Polished up the chock cup and made a advance / retard leaver
And while I was in the making mood I cast a new prop nut
Still need to polish up the leg a little more!
Takes a few pulls of the starter rope to get the fuel up the fuel pipe but once it is there she runs like a champ!
https://www.youtube.com/watch?v=boPmmzwZMvs
I could only run her for a minute or two because she would not pump water very well with the prop on!
(Sorry about the quality of the video, I only have my cell phone to record with)
I do have the black instruction plate but I dont want to put it back on until the rest of the engine has been cleaned up.
If they were still giving The Queens award for Industry, I think that piece of work would merit one, Chris.
I think you've put us all to shame!
Thank you very much Charles.
If it wasn't for Bruce sending me his fuel tank and mixer I would not have been able to get it even close.
I am in awe of your skills Chris.
This has been an absolutely fantastic thread.
Thanks for sharing.
Thanks for sharing.
This is brilliant.. I have just reread the post and the work, process and help provided is amazing.. this is what the forum is all about; fantastic job..
Really good work that. Great skill and attention to detail.
This all worked out VERY well Chris.
Outstanding work!
My example has been pulled down suffering a cracked piston and a very suss con-rod. I will reuse the cases as special for our model and use donor internal parts from other more recent ones that are hanging around. The case castings remember.
2016 is a return to GREEN.
CYA later Blue.
Outstanding work!
CYA later Blue.
Once again thank you very much for the loan of you mixer it would have been an impossable task without it!
Bit of a shame that the piston is cracked on you one. yes if it where me I would I would use an old red to rebuild the black.
That Anzani is a Very Lucky Outboard. I doubt anybody else would have the skills , or put in the amount of time and effort, that you have done. Another Vintage Outboard saved from a box of parts.
I am looking forward to seeing what your next project will be.
Cheers,
Mark
Cheers,
Mark
I'm thinking it may be a scale model of a 100 series or maybe a 102? All cast and working of course!
Nudge wrote:I'm thinking it may be a scale model of a 100 series or maybe a 102? All cast and working of course!
Really?
Make two aye!!!!!
The first thing I need to do is measure all of the parts of an engine and come up with a few simple drawings and sizes.
When I do make a start and have some patterns I will cast a few at a time (and put it into a new thread)
