Page 1 of 2
British motor boat mfg co Ltd
Posted: Thu Apr 16, 2015 10:25 pm
by flyguy
Saw this on ebay, and thought someone might like to see it
http://www.ebay.co.uk/itm/Outboard-engi ... 33a0f6285a
comes with original packing case
Re: British motor boat mfg co Ltd
Posted: Thu Apr 16, 2015 10:52 pm
I did spot that, nice condition, with all the extras.
Posted: Thu Apr 16, 2015 11:38 pm
Britannia MK 2 looks pre war, clever tiller arm on these.
Posted: Fri Apr 17, 2015 12:17 am
Very nice. Why the what looks like a box spanner on the starboard side going to under the stator plate?
Posted: Fri Apr 17, 2015 2:04 am
by AusAnzani
That BMB is absolutely beautiful.
I sincerely hope one of you guys in the UK pics it up.
Posted: Fri Apr 17, 2015 10:10 am
Sliding tiller arm on these Hugo, 360 degree rotation, when you want to reverse, slide tiller arm all the way in, rotate motor 180 degrees, grab hold of tiller to steer, rotate tiller to operate throttle, like a twist grip, Clever!
Posted: Fri Apr 17, 2015 6:13 pm
I have a fairly early one of those, interesting engines but little or no spares availability. I suspect that this one has a later magneto fitted from the later power head as fitted to midi and the britannia inboard.
the weak spot is the cooling system which does not have a tell tale and thus you don't know if water is flowing or not.
also the magneto uses a coil with a dual output, I bought the last NOS one a Birmingham parts dealer found and he assured me he had no more, so it is quite likely that coils are unobtainable.
Posted: Fri Apr 17, 2015 7:17 pm
This is a water scoop one, Oyster, not the vacuum prop version, so has positive water feed, & it has the Villiers twin spark coil not the Lucas, was yours a Mk 1?
Posted: Fri Apr 17, 2015 8:54 pm
Yes Charles it has the earlier mag it is a lightwin I didn't realise that model had a mark 2 variant with villiers mag
Posted: Fri Apr 17, 2015 9:47 pm
Britannia
Mk 1, 172cc ,1932 to 1934 Lucas Mag, vacuum prop cooling water suction.
Mk 2, 165cc ,1934 to 1946 Villiers Mag, behind prop water scoop.
Both with reversible throttle tillers.
Posted: Sun Apr 26, 2015 2:33 pm
this one has now arrived at its new home, also in Derbyshire 8)
Posted: Sun Apr 26, 2015 5:53 pm
by flyguy
Oyster 49 wrote:this one has now arrived at its new home, also in Derbyshire 8)
Well done you got a bargain I think
as someone who knows nothing about engines it does suprise me how much this the British Ansari and a Coventry look like Seagulls
is there a connection?
Posted: Sun Apr 26, 2015 6:57 pm
None whatsoever
Posted: Sun Apr 26, 2015 7:41 pm
by flyguy
Thanks Charles, I need to start reading up on these other makers
Posted: Sun Apr 26, 2015 8:35 pm
Try Peter Hunn, The Old Outboard Book, most have it.
