thoughts? Ideas? Jokes?
Posted: Mon Apr 20, 2015 12:51 pm
Once upon a time..........
Took the boat and my nice shiney (new to me) '69 Century, to the their summer home, (up state N.Y. on the St. Lawrence River, Clayton N.Y.)
Dropped the boat, (19' Grumman SF Almn. fishing boat with a 70 H.P. Evinrude motor) into the water.
"Yep, still floats"! (always amazes me when it does)!
"Rude fired up, new prop worked well, new impellar wasn't spitting water out the "tell tale" hole but a GOOD STREAM, like a guy who been drinking all day STREAM!!,.
Head out, (feel good to be on the water again)! Turn on new "fish finder, chart plotter", got that all set up.
(water was 39 degrees!
, saw a few "ice burgs" out there)!
Got out in the river, dipped the Sea gull, a good "tickle" of the carb, a few tugs and it came to life
Some quick movements, dash to mid ships, (I have a throttle control at the captains chair, so I had it on full throttle, start), pull the rope, catch my balance, run to the control, lower the rpm, find the pull rope that I threw to the deck during the mayheim.
Looka!! It works!!!!
Pushes the boat into the wind and current 4-5 mph, good enough for me!
The linkage I made to steer off the "Rude" with the steering wheel works great!! Easy to install, good turning! Life is good!!
Turned, (have to turn easy, prop loses bite on a sharp turn or it came outta the water)?
Maybe after it starts, I have to put it deeper in the water? (I have it set for 1" above the lower unit pinch boat)?????????
Pointed down river, the wind and current helping us along, that when it all went bad.........
Rolled over a wave and snapped off the NEW latch pin, (must be a common problem, as it came with a broken one, and the '75 Silver has a broken one.
Works fine without it, but.........................
How can I fix that???????????????????????????????
Then, I dropped the speed to 1- 1 1/2 mph ("trolling speed").
The S.G. is just above stall speed, (on the "pilot jet" is what we call it on motorcycles, idle to 1/8 throttle).
At the low rpm, no water.
A bit more rpm and it will spit water out fine, but not that low on the tack.
Thoughts? ideas? on how I can fix that?????????????
The motors sounds COOL out there, I like the rumble, the throaty sound.
I was surprised there wasn't a lot of 2 stroke smoke either! (10:1 mix, NOT synth. 2 smoke oil)
Latch pin issues and low speed water flow ideas, how deep do I set it up when running???? thoughts, ideas???
Maybe this motor isn't designed for what I want to do with it? a low rpm trolling motor???
Thanks
Joe
Sometimes the stars align and all is right in the world!
Thanks
Joe
