Silver Century project, shipload of questions
Posted: Mon Apr 27, 2015 12:38 pm
This is on a 1975 Silver Century non gearbox lower unit.
My "list of parts" I had going my kids stole from the clipboard, and ordered, (my Father's Day Present! At last something good), all came in, (if I had know they were going to to this, I'd made a BIG list)!
Had some time yesterday afternoon and thought I'd start on the re-ringing.
Figured I tear it apart, spend the week, giving "IT" a good exam, poking, cleaning, getting it done, NOPE!
First the headbolts...........
I was READY for the battle, torch was out, 2 cans of rust penatrate on the bench, a beer, (this was run in salt water and looks like it wasn't well taken care of).
The bolts were jjuusssttt snug!? they were really easy to get out!
Looks like the head gasket was leaking.
The water jackets were filled with rust "gunk" and some rust chunks. (A ice pick, coat hanger wire and a pressure washer got them cleaned out). It'll run a lot cooler now!
All together, checking, tinkering, looking at how it's make, taking my time, it took 2 1/2 hours to re-ring.
Hey MR Sea Gull! If'n your reading this, put a slight bevel at the base of the cylinder! It'll make putting the cylinder over the rings a lot easier! Check out how motorcycles do it! Please!
Bushings for crank bearings??!! Anyone ever try to retro roller bearings?
How about porting the transfer slots?
I HAD thought I could get a little more out of it by some grinding but the 1 common sense brain cell told me to back away from the grinder!
So, I listen to it and broke the glaze on the cylinder instead!!
(My reasoning that won over was that I don't know the "window specs, and can't flow test this cylinder, so leave it alone-clown)!
I had thought about the 25:1 conversion, but after seeing the bushings, I WANT as much oil in the bottom end as I can get!
I also applaud the engineers for the designing the top of the piston rod! most bikes I've worked on have a 1/8" hole for wrist pin lube. This has a nice big slot! I LOVE IT!!
Presently when I left "IT" last night, I have it all re assembled, but the "jug"? "cube"? (I like that, "cube"), bolts are hand tight, the head the same.
On the base gasket I used Silicone "gray" (high torque silicone), and orange "high temp" silicone on the head gasket, (first time i ever used ANY type of sealer on the head gasket)!
A put a really thin coating on both gaskets.
Looking at the lower unit and the real questions...........
1). the screws..... dis similar metals in salt water, heads are rusty, best way to get them out? (heat and tapping, then a impact screw driver)?
Chances of getting them out in 1 piece??
The lower unit is dribbling oil. Like a good British machine should (I think of my BSA)!
I want to replace the bushings and seal.
Best way to get the bushing out and drive the new one in?
(I'm 99.99% sure I'm going to do a gear box swap , but want to refresh this unit)
Any tips, things to check whilist I'm in there?
Best way to break in the motor after I fire it up?
Thanks to all!
Joe
Thanks to all!
Joe
