new rings
Posted: Fri Jun 05, 2015 8:29 pm
Hi just put a new set of rings on my 40 plus
had 70 psi so thought it was about time i did it, she has now got 120 psi.
This is the first engine i bought and is not original its got a British racing green long range tank and a very light green crank case and magneto,
i really did not want to spoil the paint so was very carefull
all the nuts are painted so putting spanners on them has spoiled the paint, i put 4 new head bolts on but reused the 2 crank bolts
it came apart very easy
the water flow has never been brilliant but it did flow so i was surprised at just how much crud was in the water passages, the top half was clear
but the bottom around the water inlet was solid with a tiny hole that water got through and a sort of rusty sandy sludge for an inch up
any way, put it all back together and the next evening give it a run in the barrel and it worked a treat great water flow and more power so time for a day out.
We decided on south stoke on the Thames its a very long stretch between locks , it runs from streatley down stream through South stoke Cholsey moulsford
wallingford and up to benson lock.
Needed some 2 stroke so popped into Sheridan marine, (the home of British seagull today) and then the thought occurred to me forum members would probably
like to see it to,
so heres a link to youtube https://youtu.be/s1jHoSkcQYk
like to see it to,
