Villiers MK12HS
Posted: Sun Feb 28, 2016 8:07 am
Picked another Villiers up this morning.......I dusted it down.
Very original with a weak spark and some compression.
There are lots around you just have to pick your MK so to speak
I do not know serial numbers but this one would be at the end of production.
Australian Champion 7 Com -L. Interesting in itself.
Pleased
BnC[/color]
Re: Villiers MK12HS
Posted: Sun Feb 28, 2016 8:30 am
by notav8
Nice Find. You may find that the valve clearances have closed up. All the ones I have played with, have had that problem. A quick valve grind, and it will likely be good as gold, as far as compression goes.
Cheers,
Mark
Re: Villiers MK12HS
Posted: Sun Feb 28, 2016 9:39 am
Thanks Mark..........totally Cool aye!
Between this Small engine kit
and an older style hand valve profile/cutter should be sweet!
I will service it and start it first. One Day.
Looks good under the TV stand by the way.....
BnC[/color]
Re: Villiers MK12HS
Posted: Sun Feb 28, 2016 10:09 am
by Nudge
Looks like it is in good condition. Nice find.
Re: Villiers MK12HS
Posted: Mon Feb 29, 2016 9:16 pm
by notav8
Nice Valve Reseating Kit. On an engine as nice as yours, it probably only needs the valves cleaned and lapped etc. Love the idea of a Villiers under the TV LOL
I doubt I could sneak a motor into the house, and certainly not close to the TV.
