Seagull Serial Prefixes
Posted: Tue Sep 20, 2016 10:10 am
by AusOB_Collector
Hi all
After recently coming across one or two not-as-common Seagull serial prefixes I thought I might see if we could all attempt to compile some sort of record for the not-as-common/ strange prefixes you've found on Seagulls.
Recently on eBay, I came across an SJPR which I personally haven't seen or heard of before. According to the serial identifier, there is a possible error in the serial #. Would this be the case of a mis-stamp or similar?
BP
Re: Seagull Serial Prefixes
Posted: Tue Sep 20, 2016 10:36 am
Try it again, but this time remove the R, which stands for factory reconditioned.
Posted: Tue Sep 20, 2016 5:53 pm
Quite common this Boyd.
Anything with the letter R in its serial number indicates a factory "refurbishment".
Plenty of motors around like this. I thought you knew this already!
Posted: Tue Sep 20, 2016 6:25 pm
Except some of the later motors with fuel pumps they used the R to signify "Remote Fuel"
I though you knew this already!
Posted: Tue Sep 20, 2016 6:52 pm
You mean like the SKR Charles?
Posted: Tue Sep 20, 2016 8:09 pm
by chaldon3
this seagull is just up the road from me, and found the engine id on site could not identify.
i was not aware British seagull would have refurbish. but i guess that makes sense.as this day you buy then throw most items.
interesting, so much history and a little mystery at times with seagull.
Posted: Tue Sep 20, 2016 11:11 pm
The R can be a bit misleading at times, as the R seems to have got stamped just about anywhere in the serial number that had a space for it to fit. Or you would get the crank case completely changed and it would all got re-stamped.
Posted: Tue Sep 20, 2016 11:19 pm
You took your tired old outboard to the factory outlet, paid your money, &walked out with the same model that had been subject to a complete refurbishment.
This applied to almost every model except it is believed for the Little Forty series.
Posted: Wed Sep 21, 2016 11:00 am
by Gannet
Yes Charles, ref Little Model Forty.
There are examples of the FVs having new crankcases fitted (by whom I do not know, but possibly by the factory) and just being restamped without an R in the serial number. Certainly I have no record of a F, FV, FVP, LS or LM with an R stamp.
Posted: Wed Sep 21, 2016 10:08 pm
Out of curiosity have we seen any magazine adverts or similar advertising the factory exchange/refurbishment?
Posted: Wed Sep 21, 2016 10:16 pm
Yes I think some were posted on here.
