transom rake and thrust bllock
Posted: Sun Apr 23, 2017 10:33 pm
Century Silver Century: When adjusted for transom rake on my boat, it is necessary for thrust block to be in one of two aft holes of the mounting bracket, but it then rotates down when motor is lifted. Must I use a wedge shaped wooden block between engine bracket and transom to get the angle correct? In any event, it looks as if only the two holes nearest the transom are available for this purpose as the thrust block rotates too much in the other two holes.
