And Another New Seagull Owner
Posted: Wed May 17, 2017 10:57 pm
Hi all! Greetings from sunny East Central Florida, USA - the Space Coast. So called due to the Kennedy Space Center a few miles away.
Yesterday I spotted a British Seagull for sale on the local Craigslist. Pictures looked good. Price was reasonable. So I crawled through this whole website and related sites to educate myself before looking at the motor. My previous experience with Seagulls was back in 1978 when I helped a Coast Guard colleague deliver his newly acquired Cape Dory 18ft Weekender down the New Jersey coast on a day with a rousing easterly blowing onshore. I was impressed with the Seagull's power to push us out the inlet against a very foul flood tide.
I currently own a 1972 Gulf Coast 20 sloop manufactured in Houston, TX and designed for good performance but with a cuddy for two to overnight. I've been using a 2hp Evinrude I bought new in 1984 for a 24 ft sharpie schooner I had built. It is adequate for the GC 20, but the Seagull seems a much better match on several levels - especially for a well preserved vintage sailboat.
The seller had acquired the motor from his uncle who purchased it new and estimated between the two of them the motor has about15-20 hours on it. It has been idle for a while but appears well treated. The seller believed it to be a 1985 3hp, but running the engine number shows it to be a Forty Plus built in June 1979. Edit: As mentioned in my next post below, I goofed - it is actually a Forty Plus built in June of 1969. Even better.
After a good look over I paid the seller his price and brought it home. He had commented that he couldn't get it to fire after sitting so long. I pulled the plug (Champion 8 COM made in the U.K.) and discovered the electrode closed down as if dropped. No carbon and light wet oil on it. I believe it is the original plug. I won't try and fire it up until flushing the fuel system & carb and changing gear case oil, but I had to check the spark by grounding a plug to the cylinder and giving it a pull. The plug slipped off the motor and I can attest it has good strong spark - my hand tingled for several minutes.
By tomorrow or Friday latest I should have fluids freshened up and a couple of aging seals like the gas cap freshened up and try to fire it up in the test barrel.
I must say I am thrilled to find an active forum and active support for these great old motors.
