I'm away from home (and special tools) on a job, but recently rescued a 13' wherry and a '72 Silver Century plus (WSPC 1561C2) from a journey to the landfill. Salmon are running here so had both in functional shape in a couple evenings so I could fish the river.
I did all the usual seagull life-giving procedures...she came back ok and starts and remains running...just one glitch...
Warm or cold, the gull four-strokes and will not tach-up. Runs indefinitely, exhaust level normal, temp and waterflow fine...no backfires but am getting residue on the storm hood of the carb as four-stroking will do. Did a proper job cleaning carb and fuel system. Did points, new plug, fresh non-ethanol 91 octane fuel at 10:1 mix, etc.
The carb is an Amal 46NL. Don't have my jet tool with me but carefully checked with an indexed drill bit (smooth end) and I believe it's still jetted 10:1. Needle and float appear fine and clip is in the notch.
Yesterday enroute to my salmon spot I fussed with the fuel tap and tank vent until I figured fuel flow was reduced to a minimum...she smoothed out and ran up to a decent rpm for my 20 minute run...not perfect but not stroking. The day before it had smoothed out for a few seconds before stopping after I shut off the fuel tap to coast in to my fishing spot, so I figured too much fuel might be it. My '46 Taylorcraft aeroplane (like an Auster) jumps a few rpm just before stopping by shutting off the fuel, but it's a four-stroke continental engine.
There are no other problematic symptoms. Compression is 65 lbs. Spark is fine. No improper leaks or seeps anywhere. On the off chance that I'm mistaken about the carb being jetted for 10:1 I considered trying 25:1 fuel, but I have always run 10:1 in 'gulls and prefer that...plus, seems to me that 10:1 mix in a 25:1 carb would lean things and prevent the problem I'm having, not cause it. Again, the needle is fine and the (plastic) float looks fine and bubbles not a whit when immersed in a water bucket.
Apologies for the long post but the devil's in the details. Figured it's something simple and my seagull memory is failing me.
Thanks!
