Another SD
Posted: Wed Sep 05, 2018 2:11 pm
by mauriziopiras
Hi guys,
This is the new SD newly arrived after a long trip.
I know: some components are to be replaced.
All tips are welcome
Maurizio
Re: Another SD
Posted: Wed Sep 05, 2018 2:18 pm
by mauriziopiras
For Hugz: it has no JM number on the flywheel
Re: Another SD
Posted: Wed Sep 05, 2018 2:36 pm
Great. Love those brass carbs Mauriziopiras. Can't quite decipher the engine number.... SDxxxxL4. Cheers Hugo.
Re: Another SD
Posted: Wed Sep 05, 2018 3:49 pm
Have a look at your last flywheel picture at 6 O'clock on the baseplate, you will see the letters "JM" underneath that spoke of the flywheel you should find the rest of the number that Hugo wants.
Re: Another SD
Posted: Wed Sep 05, 2018 3:51 pm
My first SD was also like that, the flywheel had no stamp, but the baseplate had the stamp.
Re: Another SD
Posted: Wed Sep 05, 2018 9:10 pm
by mauriziopiras
Hi Hugo,
JM number (in the baseplate) JM 2717
Serial:SD9984L4
Maurizio
Re: Another SD
Posted: Wed Sep 05, 2018 9:40 pm
Excellent thanks. Fortunately with the later SD's the gearbox casing, l believe, is the same as the early C, D AC and AD with nipples on the Port side. The alloy is slightly different but it would be a fine eye that would pick the difference. Wonder why a lot of the fuel lines have been replaced? I'm assuming the clutch lever has patent inscripted on it?
Re: Another SD
Posted: Thu Sep 06, 2018 8:00 am
Edit: I already have this motor listed! I have the clutch lever as plain which is a bit of an abnormality but #SD10100 is also plain. Thanks for the JM number that I didn't have. I'll update location as well. Yay.
