ESC
Posted: Tue May 12, 2020 2:29 pm
Carb has had a good clean up all back together as should be
Push the tickler to get the fuel going
Problem is that the fuel won’t stop flowing from the tickler
It is also dripping from the choke housing
Stripped it down again the float is moving freely
All back together same thing
The fuel needle is in the correct spot
