Early 102 on the Bay
https://www.ebay.co.uk/itm/Vintage-Brit ... %7Ciid%3A1
Looks early 47-48?
Guy says "It would be prudent to clean the carburettor and rinse out the fuel tank before starting"
I would guarantee it will need a new coil and condenser, clean the carb is the least of your problems.
Did run decades ago when last used, classic :lol:
Still a good project.
Aluminium C clamp transom bracket, rare I thought.
Just checked http://saving-old-seagulls.co.uk/phpbb3 ... .php?t=663
Re: Early 102 on the Bay
How about that...has solved a mystery for me.
My friend has AD2710
Except for clutch of course and...
No aluminium brackets but has 90 deg clamps.
It looks like AC2721 has a cracked block?
That looks like a really nice original example. Very nice 8)
dave_halst
Post by dave_halst »
Happy to report that AC 2721 didn't have a cracked head and fired up on the 4th pull. (the eBay image did look like it had a crack but I was assured by the owner that it didn't) A full water test is next on the list on John's recommendation. (I'll make sure the container is large enough)
Yes, a great buy that. If you look on the SOS main web pages there are some prints of early post war magazine tests, showing an exactly the same engine.
It is looking good, was surprised it had a spark, could be arcing between windings, hope it is sound.
Will be interesting to see it run in water, I find that the older villiers condensers fail when they get hot.
Normally after about 20 to 30 minutes of hard running on a boat.
I replace them if I want to use the motor other than in a test tank.
https://www.ebay.co.uk/itm/M1750-Conden ... XQ-KRRhzL-
Reliability keeps the stress levels down :lol:
