Side Mount Bracket
Post your wanted adds here
Side Mount Bracket
Just a stab in the dark with this request aye.
The motor is complete and nice, recently imported down-under.......Mission.
Side mount bracket wanted as per the pics.
Hope so
Re: Side Mount Bracket
Standard Wartime bracket part Bruce, ask Hugo he will have all the pictures of the bracket& there might be some on here.
Thank you Charles and yes that is what needed.....and waiting with bait on my breath.....so to speak.
Here you go Bruce, Hugo has got one of those brackets if I recall.
SD side mount.jpg (69.95 KiB) Viewed 36733 times
The lower picture has the correct thrust block but bracket has been cut and welded right at the top, to fit a much thinner hull, possibly on a transom.
Whereas the top picture has had a top support fitted in place as a thrust block, & some weird device attached to the top support, so no ability to tilt, don't hit anything underwater!
The black one I got, I always thought it had been modified by the owner to fit a transom until I cam across another identical bracket which indicates either they were made like that as I’ve never seen a wider version or several were modified together.
On closer inspection I think they were possibly manufactured like that as the piece were the arrow is pointing is a shaped one piece of metal forming an integral part of the bracket, if the bracket had been narrowed there would be a weld where the bracket had been cut.
Rene can you attach it onto a drive shaft tube & take a picture, from these pictures the top & bottom fitting don't look to line up.
All very good and does someone want to sell me one?
Only a few known. I recall Hugo bought one a few years back?
I've seen 3 & I believe there were a total of 5 that were known about, a couple of years ago!
I have enjoyed everything above.
For some reason I ask for old things that are not really available.....trending with that aye.
I will make do with a conventional bronze transom mount (period correct) from what I have.
Thanks to everyone for the added info of course.
I will post the Old Dear in one clean assembly soon.
