Hi, I am trying to identify the exact size of the two retaining screws for my Amal twin-jet throttle lever. It sits on a Silver Century WS.
I suspect the screw is a BA 1, the approximate dimensions are 5mm od and 5/16" length with a rounded slot head. Is this about right?
Thanks in advance
Throttle Lever Retaining Screws
Re: Throttle Lever Retaining Screws
1 BA is 5.3 mm diam and 0.90mm pitch. thats 28.2 tpi
Odd numbered BA sizes are very unusual ( except in older electrical stuff)
do you not think it is 3/16" Whitworth. 0.1875" diam (4.76mm), 24 tpi
Same control as the Villiers carb AFAIK and they are 3/16" Whit in that! The diameter is a bit under spec but 24 tpi no doubt but 7/16" long
Thanks Vic, I was being a tad lazy in not getting the Micrometer out.
But I suspect you are probably correct.
Thread size is 1BA. You can get stainless or chromed ones from Custom Fasteners in Newtown - they have a website - customfasteners - oddly enough - that you can order from.
- 40TPI
Not really. Have a look at :
http://www.britishseagullparts.com/engine-throttles.htm
I haven't got any better "one I took earlier" pictures to hand and it saves wearing keyboard fingers for the rest of it............
Peter
Should have mentioned that Custom Fasteners don't supply rounded headed screws - only 'cheese headed' type, but these are normal to the type of lever I think you have from the sizes you are quoting.
The earlier levers had screws with a raised countersunk head, and from memory I think were a finer thread.
Thanks Rick,
yes I saw that and have ordered the 1BA cheese slot head
