Port sizes
Hinchy1964
Port sizes
Ok so I have decided to take the barrel off one of my seagulls to see how they work. The first thing I notice is the difference in the size of the port allowing fuel/air into the cylinder. One being a lot more elongated. Surely these ports would be better matched to the same shape. Or are they. Has the engine got a different barrel than it should have?
Also the old base gasket covered half the port area on the barrel, presumably to match the size of the crank case port. Surely the resticting gasket and the miss match in port size cannot be good for the fuel/air flow which is creating a ledge above the base gasket and may encourage oil/fuel to hang around and maybe de-atomise before it finally goes into the cylinder.
Ian's new theroy - 'smoother delivery of fuel = Improved combustion'
So me thinks in my tiny little mind. Why not at least chamfer the edges of the crankcase port a little to elongate the opening, alter the gasket accordingly and thus make better use of the width of the port on the barrel smoothing out and chanelling the flow of fuel/air? Would that upset everything? Maybe the crank case port size is important? But in that case why make the barrel port wider?
Ha ha, as you can see I know nothing about seagulls or in fact engines whatsoever and I am sure British Seagull would have improved the design if at all possible.
Re: Port sizes
What's the serial number on that crankcase the cylinder looks like an LLS or an early CP,
you could well be right, a miss matched crankcase & cylinder.
Hinchy1964
Re: Port sizes
Hi Charles
The serial on the crank case is CPCR. 5485
It is a short shaft but with the larger gear box and 11" prop., villers carb and villiers ignition and clutch fitted.
The block has been painted gold but underneath it looks like it was originally black if that helps.
I wonder if the block was fitted when it went back to Seagull for a recondition? (R in the serial number) or even a different crank case?
By the way what is an LLS?
Thanks
Ian
Thanks
Ian
Re: Port sizes
An LLS is the first of the Centuries. Very very similar to later Centuries its letter code bore no relation to reality as far as I can see.. Whereas 'C' was for Century, 'CPC' for Century Plus with Clutch' 'LLS' doesn't seem to stand for anything at all.
The other Charles will doubtless be able to offer some insight into small differences.
This business of different port sizes is interesting. I can't throw any light on it!
Re: Port sizes
The cylinder is right & matches the serial number, but the crankcase is quite a bit later, so it's probable that during the Seagull repairs, the crankcase was replaced sometime post 1967.
Hinchy1964
Re: Port sizes
Ok Charles so does this mean I need to look for a century or century plus pre-67 crank case to make the ports match up or would a better idea be to locate a post 67 block
Or could I just put the whole bottom half (i.e. larger gear box, 11" prop and clutch) onto my other Century WS11DD6 to create something for a 16' Yorkshire pebble type boat.
The Century plus has a little more HP is that right.
Mmmm.....
Mmmm.....
Re: Port sizes
Put it on the back of your boat & try it, & then swop the bottom end over & see which one you think is best.
Hinchy1964
Re: Port sizes
Ok, good advice.
Thanks
Ian
Thanks
Ian
- The Tinker
Re: Port sizes
I have a century 100 that looks the same miss match got in there with a die grinder and matched crankcase to port, made it go a lot better.
Re: Port sizes
This has set up for some interesting discussion.
Think "Velocity" and get cracking!
Hinchy1964
Re: Port sizes
Another miss-match. This time a crank on ebay (supposedly for a large 100+) which clearly shows where the block was.
I wonder how many more are like this. Or was this standard practice by British Seagull?
Is the crank case the same for the 40's as well as the 100's or are there differences?
Has anyone any pictures of a crank case with an elongated slot to match the block in my picture?
Hinchy1964
Re: Port sizes
Thats interesting Hugz, yet another shaped port.
There is a base gasket on ebay at the moment for a regtangular port shape like that.
I wonder now whether to resort to a dremel to reshape the crank case and fabricate a base gasket to match the curved port on my block.
Unless anyone knows of or sells the correct shaped base gasket for mine.
Ian
Ian
Re: Port sizes
Ian there are numerous different cylinder castings, yours probably has a bridged transfer & exhaust ports & has the inlet port on the Port side, though it is the smaller inlet stubb designed for the Villiers carb.
Hugo's later cylinder has the Amal sized inlet port on the Starboard side with the transfer & exhaust unbridged.
It's a long time since I worked on any of the early classic motors like yours, but from what I can remember the transfer port notch in the crankcase was wider almost matching the cylinder in a lot of the pre 67 crankcases.
From memory from my long ago research into best component matches for racing, the SD crankcase was the best fit, though it would require some engineering work to the retaining studs to make it fit.
Use any gasket as long as it's at least 10 thou thick, & clean it up around the transfer with a scalpel.
Hinchy1964
Re: Port sizes
Thanks Charles.
Your quite correct. It has bridged ports.
What colour was the block originally by the way? There is black paint under the gold. Would this be correct?
On the subject of paint what would be the nearest modern-day available equivalent silver/grey on the gear boxes and prop?
Many thanks for everyone sharing their knowledge
