Water pipe seal
Water pipe seal
With the thought of getting any water pumped out of the water pump up to the cylinder and seeing the water pipe fit into the water pump housing as being a poor slip fit at best i've fitted this. An 8mm spring grip washer, a slide spring from an Amal carb, a plain 8mm washer and a couple of o rings. this spring loads the o rings against the housing. If it did leak before, it won't now.
