I have a running problem on a 40+ that is puzzling me.
Sometimes after a period of normal operation the engine begins to sound as if it is struggling and revs drop significantly - sometimes stabilising at a lower speed, sometimes continuing to head downwards as if the motor is to stop.
What I have found is that comnpletely obstructing the air inlet with the tip of a finger for a fraction of a second and then releasing it causes - after the momentary downwards blip - the revs to immediately rise again to the normal level and the engine to continue running at full power.
One more thing to look at is how do you mix your petrol and oil. I was out yesterday and someone had the same problem.. He was putting oil in the tank then adding petrol. the oil was sitting in the fuel pipe .
Hope this of some help
Stephen
