Spark plug & ht cap
Cpt pug wash
Spark plug & ht cap
Post by Cpt pug wash »
Hi new to this forum :) lots of interesting stuff on here. Thanks
Back to the question , I've recently purchased a seagull serial sjm 2060b6 , going out on the water with it
For the 1st time with me anyway , so I thought I would do some basic maintenance :oops:
( if it's not broke don't fix it springs to mind ) thought I would take the plug out & clean it ,
Broke the original seagull cap & plug :shock:
I put a screw on cap on tempory & a li4 u plug new denso
Is this plug suitable before was a ngk a7 ?
Also I was running the fuel mix at 10/1 which it says on the fuel cap it ran fine bloody smoky though .
& responsive on the throttle, now I've gone to 25/1 it isent responsive on throttle , but the smoke has gone ?
Imm using proper outboard 2stroke oil duckhams.
Don't want it to let me down on the 1st outing :lol:
Thanks mark
chris
Re: Spark plug & ht cap
Post by chris »
Welcome to the madness
I use a champion D16 plug and you should run yours on 10/1
can't remember the ngk plug to use, try the faq's
supersaint61
Post by supersaint61 »
A6 or AB6 plug
Vic
Post by Vic »
I think you will find that Denso L14U are the equivalent of Champion D16
The original Seagull plug caps, with the screw terminal on the top, are a PITA at least they are when they get a bit worn and keep coming unscrewed.
Unless you must have the "correct" cap for authenticity use any cap that will fit the plug and that does not have a built in resistor.
Cpt pug wash
Thanks for advice guys :wink:
Ohh by the way the 1st trip was a success the ol seagull done well :D
