Crank shaft bearing lengths
Dranreb
Post by Dranreb »
I've searched for this info but it's eluded me, so I hope you don't mind another newby question
I have re-built my very clogged up and seized Seagull bitza and got it running, started second pull! No wonder people love these things :D
As there are no engine numbers on it, I am wondering if the crankshaft bearing length is any indication as to what mix to use, the drive side one is 32 mm, and the flywheel side one is 43.5 mm long, if that helps.
Hoping the smoke will get less as the assembly oil washes out and the mix is corrected, this pic doesn't show much smoke but it is a filthy beast right now. :shock:
Re: Crank shaft bearing lengths
It looks like an LLS long shaft , with the wrong tank.
I don't know about crank lengths, but it should be a 10:1 mix
Dranreb
Post by Dranreb »
Thanks for your reply Keith, I suppose I was hoping someone would say the replacement crank cases are of a later type that can run 25:1, but thinking about it maybe the crank shaft would have to be longer too..
I'll run it some more with the correct 10:1 mix and see how it goes..
Don't you mean an SJP or an FP? still at 10 : 1.
Dranreb
Post by Dranreb »
The tank support looks like it is made for an oval strap on tank, and the prop is a 9" straight bladed one, is that any help identifying it Charles?
None whatsoever.
That looks like a Seagull 102 tank, long range.
I doubt if the tank bracket ever saw the Seagull factory gates.
That's a 64 cc Seagull that's all we can tell for certain.
We need good pics of gearbox, prop, powerhead, ignition, cylinderhead.
Dranreb
Post by Dranreb »
Some pics to ponder
gearbox
Prop
Head and bracket, (screw and hose clip by me)
The ignition is points type same as my 40 minus.
After much googling I found this picture,
This one is said to be a Silver Century Plus, it has a similar tank bracket.
So my Seagull may be a proper bitza made of spare parts to keep it going cheaply, (the tank was loosley held on with twisted copper wire)it came from a full time fisherman so this would make sense, as it was free I never asked much about it.
Let me see.............."it is a filthy beast" and a "Bitza" ?
I think that your motor will have character and will be running nicely very soon.
Daryl
Post by Daryl »
If its not a Filthy beast, then its not a Seagull. If its a bitsa who cares solong as it goes & reliable, then Enjoy a very practical outboard.
Niander101
Post by Niander101 »
I use 10/1 for all my seagulls nice and simple and i dont mind smoke
and yes it is a filthy beast" and a "Bitza"
and ye thats a brass long range "oval" not round!
tank bracket
but i know you still love it :D
