TC--102
Stelios_Rjk
Re: TC--102
Post by Stelios_Rjk »
Kean leaking occur some times when the contact of the ferules and the fuel tap or carb is not perfect. When that happens I add some teflon tape and the problem is solved.
If you apply too much power you may distort the ferules as it is soft brass.
Re: TC--102
The original fuel tubes fitted to Marstons, SDs, 1940s 102s, and the FV/FVP engines used soldered on joints, rather than compression olives. These fittings are available.
1650bullet
Re: TC--102
Post by 1650bullet »
I will try a bit of teflon tape and see how that goes first. If no go i will go and see the fitters at work and get them to make one up. As for the hot starting dramas im having. I checked the magnets on the flywheel and one side does not magnetize. Is this normal.
Re: TC--102
Hot starting probs can be because of crankcase halves not sealed.
You checked yeh?
Maybe stay shy of ignition for a bit.
Nice job of it by the way.............. :)
1650bullet
Re: TC--102
Collector Inspector wrote:Hot starting probs can be because of crankcase halves not sealed.
You checked yeh?
When i fitted the cases back together i used a bead RTV red silastic, So im hoping thats a good enough seal. Is there any way to check to see if its leaking or not.
Re: TC--102
Red silicon......................a smidgeon maybe. Not a big fan of it as fuel eats it.
Not really proper, case sealant like Bond 2 Yamahaa or similar in very minute coverage.
If you happy with seal and faces are matched, something else then.
Blue spark is good, look further aye?
1650bullet
Re: TC--102
Just walk outside and had a look at all the studs. The top 2 studs that hold the cyl to the crankcases (under the ignition plate) were loose, Thanks for that C I I will put it back in the test tank tomorrow and try it out. Hope thats was the problem.
Niander101
Re: TC--102
Post by Niander101 »
Could well be .....I use good old red Hermetite
never had a problem.
Re: TC--102
All the RTV I use, claims to be fuel proof.
If you use the wrong profile olive/ferrule in the fuel tap or a retaining nut that doesn't suit whatever you've got on the end of the fuel pipe, it would be a very big ask, expecting it to be fuel tight!
1650bullet
Re: TC--102
Thats fixed the problem. I mounted it in the tank today and fired her up, Ran it for 5mins and shut it down. Left it sitting for a couple of minutes and fired her up again on the 1st pull and part throttle 8) 8) 8) 8) . Thanks again C-I, Your the Man and old girls rule. We may have to change your name to C S I :lol: Bloody air leaks.
1650bullet
Re: TC--102
Wet test. Very happy with it today, Time to go out on the water now.
http://www.youtube.com/watch?v=xnmgRyGt04w
Stelios_Rjk
Re: TC--102
:shock: :shock:
You were close to bend the con rod!
But it was certainly a rough test!
1650bullet
Re: TC--102
Stelios_Rjk wrote::shock: :shock:
If water was to get in it would just stop. I got swamped by a Jet-ski one day out on the water with a 40-plus on the back and no storm cowl. All that happend was it just stalled. It started back up after 2 pulls. There a pretty tough motor. Ask chris how many times he has drenched his seagulls out on the water. Im confident that it can handle a big trip out on the river now.
Niander101
Re: TC--102
What hes saying is that water is incompressible unlike air
if the cylinder is full of water it could bend the conrod
sometimes happens to marine diesels on start-up if water has filled up the cylinder
them inlet cowls are good aint they :lol:
Stelios_Rjk
Re: TC--102
Oh, I see. I would be afraid of trying something similar!
