Seagull with long range tank
Its definitely got some range to it. :shock:
http://www.ebay.co.uk/itm/seagull-silve ... 3a82f82992
BillyKnight
Re: Seagull with long range tank
Post by BillyKnight »
Ah, I see it has the "Clurch Drive". I have had a few of those. The motor is running nicely as you paddle out of your mooring then the clutch drops and you get the lurch..I think the honesty needs commending.
Is this a rare and desirable feature? I prefer the clurchless models...
skyetoyman
Post by skyetoyman »
Needs a fuel tank. How does he start it.? Silver spray can has gone into overdrive.
I much prefer a clutch.
Williegunn
Post by Williegunn »
Puts it in gear, pushes it down a wave and drops the clutch, obviously!
Has anyone tried starting a gull by using a leather belt around the flywheel?
Niander101
Post by Niander101 »
No but should think it would work :P
Niander101
But your trousers will fall down as it fires up! :lol:
skyetoyman
I thought all northeners wore braces.
