I have a silver seagull with an Amal 416 carb which is is gubbed(threads on carb body) I'm wondering if I could replace the 416 with a villiers from another silver century.. probably a silly question
Thanks
Swapping carbs
Re: Swapping carbs
Post a picture of your problem, are you sure it's a 416?
The serial number will give us a clear picture of what you should have.
Alexryan1984
Re: Swapping carbs
The problem is the threads where the banjo bolt goes into, and the float part is damaged too, it's all would need replaced as one.
Thanks
Thanks
Re: Swapping carbs
It sounds like you have the Amal twin jet 46N carb fitted to yours, give John Williams a call he might have a carb body in stock.
Re: Swapping carbs
John offers an exchange carb body I believe, with repaired threads.
Alexryan1984
Re: Swapping carbs
Thanks for the replies, got a replacement carb from tam from this page
Does anyone know the correct size for the fibre washers the Amal carb requires thank u
Alexryan1984
Re: Swapping carbs
Alexryan1984 wrote:Thanks for the replies, got a replacement carb from tam from this page
Re: Swapping carbs
You could re-use your old fibre washers.
Nothing wrong with that in my book.
Alexryan1984
Re: Swapping carbs
The problem with my fibre washers are that they aren't fibre, there copper which isn't good at all.
Managed to buy 2 sets for £5 delivered
Thanks
Thanks
