These were advertised on ebay ....... but not for long
The one on the stand is a 1914 Model B, near complete. Has a few broken bits (exhaust manifold and ignition timer) that I'll need to get on to an aluminium welder about and a few small parts missing. This is one of the first with flywheel magneto and has the 'interim brass flywheel and magneto' fitted. Both were changed again later in 1914 to those that became the norm through to about 1922 or so. Coil is shot, so I'll need to decide whether to have it rewound or run off a buzz coil / battery ignition set up.
The other is a 1913 and is missing pretty much everything from the upper crank case half and up. The crank is damaged and the flywheel is home-made. The rope sheave is also not standard as these were introduced in 1915 or 16.
Both motors turn over nicely and no strange noises. Gearboxes feel good also, albeit that the adjuster on the one on the stand has been loosened right off and doesn't look period correct.
I am hoping that together with the one I purchased last year and some bits from the US, I'll be able to assemble two good outboards and have parts available for future use.
