Is the thread pattern on the shaft bolt special?
Captain Dave
Post by Captain Dave »
Ok, I am removing the flywheel on my newly acquired 40 minus, and it is stuck. I know the drill, two man job...blow with hammer and all that stuff.
Here is my issue... I am GOING to get it off the shaft, but I wanted to use a sacrificial nut instead of the acorn that is original. I have been to the hardware store twice now and both times I have failed to find a nut with the thread pattern to match the shaft.
This seems soooooo simple, but does anyone know what the diameter and thread per inch is?
Captain Dave
40+, 40+, 40+, 40-
Captain Dave
Re: Is the thread pattern on the shaft bolt special?
so sorry... found the info just down below.
cheers
Did you look in this thread?
viewtopic.php?f=2&t=6040
Liam2k3
Post by Liam2k3 »
7/16 -18 bsf ithink
Captain Dave
OK, that makes my head spin. I found a UK source for hardware, and when I get time, I will search for a U.S. supplier. I have an old time marine supply store in San Diego that just might have what I need.
Capt. Dave
NaughtyBits
Post by NaughtyBits »
For Seagull supplies (nuts, etc. included), Sean would be close for you...
http://www.britishseagulls.com/
The part you probably require is "M1268".
