Removing Driveshaft Collar Pin
Stinch
Post by Stinch »
Don't want to damage anything. I have a replacement gearbox for my FPL has grit in that needs to be cleaned out and my SJM gearbox that is stiff. There is a brass pin #6 in the drive shaft collar #5. What's the recommended way to remove the brass pin? File off one end and drive it out with a punch?
Forty Minus - SJM 50761
Forty Plus - FPL 1890 E9
Century 100 - LLS 624 A5
andrew
Site Admin
Re: Removing Driveshaft Collar Pin
Post by andrew »
Usually the pin comes out rather easily with a punch, it’s fairly soft metal. I use an old drill bit filed flat on the ends that is sized to match the pin. A bit of heat wouldn’t hurt if it’s stubborn.
Yes, the pin can be tapped out with a small piece of bar and if its not damaged it can be reused. When refitting don't forget to peen it over so it cant fall out!
andrew
Site Admin
Post by andrew »
Z
I think you'll find 3 different types of pin, part number 1412, brass, softish stainless steel & a steel roll pin, all about 1" long & 3/16 diameter.
The roll pin comes out easy if not too rusty.
The brass one is the most difficult as the ends seem to flair out big time & can require careful drilling oversize on one end to remove the flair.
The stainless one if it hasn't been centre punched each end will punch out with care.
Try & avoid the angle grinder the collars aren't cheap!
Good luck!
I've only ever worked with the brass ones, nothing new fangled for me! :lol:
