Brass tank studs
Porthandbuoy
Brass tank studs
Post by Porthandbuoy »
Not the threaded studs on the bottom that secure the tank to the engine, the unthreaded ones on the front and back of the tank. What are they for?
Re: Brass tank studs
Lay your Seagull down on the ground to see which is the most stable position that will cause the least damage!
Porthandbuoy
Doh! Blatantly obvious once pointed out. Thanks.
