I am new to the forum. Got my first seagull on saturday did'nt know how addictive they are number 2 arrives on saturday from the dreaded BAY.From Johns home page I have discovered number 1 is a featherweight "F" I300M0 which I think is a December 1970 if I am wrong can someone please correct me.I have been reading through some of the posts and there seems to be a lot a knowledge out there . Number 1 has great compression but no spark so I tried John's trick of spinning the fly wheel with a drill( now dont laugh) only one I had available to fit that size of nut was an air wrench . Now I am in the market for a crankshaft and nut.
i tryed that spinning trick with the sd but it didnt work...
ill have to take the flywheel off and investigate....spose i could put a whole different spark set on but i gotta keep the copper hat!
As I said I didnt have the correct drill for the socket .Had the plug out and grounded I had removed the pull start plate and set about it for about 1min with the wrench I knew it had sheared when the zipping noise got louder, it left me with 2 threads and no nut to use to chap it ut with so now even they are gone.They say you learn from your mistakes, so I hope somebody out there learns from mine as I certainly will.I just wish I had found the forum sooner.
don't worry, when you get the parts you will find it to be an easy rebuild project, I have had a couple of disasters or shall we call it "learning curves"
