Page 11 of 12
Re: Santa Claus passed by my neighborhood (SD!!)
Posted: Fri Nov 15, 2013 6:39 pm
by Stelios_Rjk
Posted: Fri Nov 22, 2013 9:30 am
SWEET!
Balcony Gull looking the goods Stellios.
Posted: Fri Nov 22, 2013 9:23 pm
Any chance you can make up some of the fuel pipes Stelios? I note that Villiersparts (George?) now have the spigot nut: http://www.villiersparts.co.uk/carb.html
Motor looking good. What type of tank strap are you going to use?
Blah.. my hippie gf has made Quinoa porridge for brekky. Wish they had kippers downunder!
Posted: Fri Nov 22, 2013 9:33 pm
by Stelios_Rjk
Hi guys,
I would have done a proper presentation of my SD but I am waiting for a tap to make the carb trumpet.
No problem to make some pipes of any kind if you like Hugs :)
The straps will be as close to the original as they can be. I have found the type and they are already holding the tank.
Posted: Fri Nov 22, 2013 9:49 pm
Has John run out of the trumpets?
I think there would be a large demand for the SD fuel line. The early AC/AD's also have them I believe.
Posted: Fri Nov 22, 2013 10:18 pm
by Stelios_Rjk
No I don't think John has run out of trumpets. Just my tension to try to make everything by hand. In case I fail I will get one from John.
OK I will try to make some fuel line this weekend to see what I could achieve.
Posted: Fri Nov 22, 2013 10:39 pm
A copper trumpet would go well but not authentic... hint hint :D
Posted: Fri Nov 22, 2013 10:46 pm
by Stelios_Rjk
:D :D Thanks for the hint!
I chopped a tiller arm so I hope to be as close to the original as it can get!
Posted: Sat Nov 23, 2013 12:14 am
All the parts are available to make the fuel pipes out of copper pipe, including ferrules etc. works out about £10 or so using the correct brass ferrules and nuts. The Later AC and AD had a different shape nickel plated pipe.
Posted: Wed Dec 04, 2013 12:02 pm
by Stelios_Rjk
My new toy arrived! Wooooohooooo!!!!!!!
This inlet is totally handmade, no lathe.
Posted: Wed Dec 04, 2013 1:28 pm
Wow nice bit of work Stelios. I like the way you hold the trumpet for tapping :D
Posted: Mon Dec 23, 2013 9:24 pm
by Stelios_Rjk
Ho ho ho, Merry Christmas everybody!!!!
One year since the beginning of this post. I have just finished mixing SAE 140 with grease. I made a mixture which is like honey or with even a little higher viscosity. I hope it will be OK.
Grease gun cannot push gearbox oil (sae140). It's too thin and can't stay in the grease gun chamber. It leak from every possible way. I hope it will be able to push my "honey".
Tomorrow should be THE day!!!
Posted: Tue Dec 24, 2013 2:34 pm
by Stelios_Rjk
Finally!!
I have to thank everyone that helped me supplying parts, giving information or in any other way. Of course the forum owners for this excellent tool. Without you all guys I wouldn't have made it. Again great big thanks, especially to those that send me the original parts!
Merry Christmas and a happy new year!!
Posted: Tue Dec 24, 2013 5:10 pm
Very nice job Stelios. An excellent restoration and something to be proud. :D
Posted: Tue Dec 24, 2013 6:49 pm
by bobbybob
a nice hat (cap?) for the next season!!! :-)
not signe by steeve mac-queen but the same in "la cannoniere du yang-tse" (robert wise the sand pebbles!)
