Float bowl on Bing Carb
John1952
Post by John1952 »
Hi again guy's the bowl is leaking at the bottom, every time I screw it up it just doesn't feel right, I think maybe the thread has been damaged, any ideas!
philb
bing carburetor bowl leak
Post by philb »
Hi I have just spent some time getting an EFPC running for my son I had fuel dripping from carb bowl but when i looked closely I found this fuel was from the bowl overflow hole.I tweaked the fuel cut off valve hinge to shut the fuel supply slighly sooner and lost my drip.Might be worth another closer check?
