outboard too heavy
jimbob
outboard too heavy
Post by jimbob »
my seagull is too heavy for boat It is a 3 hp long shank Is there a smaller and lighter model
PeterW
Post by PeterW »
Jimbob
A bit more info would be useful here..
What engine is it etc, which you can get from the Serial Number. This then gives an idea of weight, and then you can work out if there is a lighter engine.
Also, whats the boat its on..? Again, this will help as you might be overpowered for the boat size
Pete
Vic
Post by Vic »
A "Featherweight" is the lightest. About 1.5 hp IIRC and the only truly short shaft (13" transom height) outboard that I know of. Also known as the Forty Minus and later as the "45"
Suitable for use on small inflatables and dinghies below 10 feet.
I use one on a light 8 ft tender and provided the water is calm it runs at WOT.
Forty Plus models are just a bit heavier and about 2-3 hp. They come in standard and longshaft versions and later ones had aclutch as well! They'd suit a larger dinghy
I have one for a Mirror dinghy (10' 10")
Jimbob
And how heavy are you in the back of the boat?
C.I.
I am sure that with Jason, John Boy, Mary Ellen, Ben and Elizabeth at the front it won't be stern heavy. :)
Good night Jim Bob
WHY would anyone know that much about the Waltons?
Very strange
woodbutchergraham
Post by woodbutchergraham »
Quite agree Charles, the soud of duling banjoes playing in the back ground springs to mind. still puts me off bacon!
But to the question in hand the 40-or+ still i think give good power to waight ratio but depends on the boat. My 40+ pushes my canoe two or three up no probs.
People are so strange, but women top the list, after 10 years she still makes a huge fuss when I use her toothbrush!
What I want to know is, how else, am I supposed to get dog muck out of the tread of my trainers?
No that was Deliverance.
Don't think there were any over weight seagulls in that film. :)
woodbutchergraham
it was all the wrong side of the pond for me ,still cant get my head around
"squeeel piggie squeel"!!!!!!
thats Just Wrong
put me off canoeing for some time aswell,
Not wanting to be pedantic but I thought that the mountain man actually said " I bet you can squeal like a pig. Weeeeeeee! " :D
Now that is sad
WOW!
C.I.
OK, Now that is all over.
C.I.
woodbutchergraham
Can you counter balance in some way. I use 6pt milk containers filled at the bank side to trim up between 6-8 work for me. I also use an extention tiller to push me forward, starting is a problem as water level often pushes the prop deep.
It was recomended buy an antipodean friend of mine i should use a biger cooler for the tinnies, but my thaughts wher that this could be counter productive.
