Do I have the right propeller?
Tonyseagull
Post by Tonyseagull »
I recently aquired three Seagulls...one I have been having discussions about on this site ...it is a SJM that has been having some water pump issues, thanks for the help so far on that one.
Another one that I have with serial number CP 14153L is a work in progess, missing a few parts but I also aquired a couple of box fulls of parts that will come in useful to get it running. There was a propeller on it, but I want to make sure it is the correct one...it is a 4 blade 11" in diameter with a code 100P stamped into it...is this the correct prop for the above serial number?
Thanks in advance Tony
Re: Do I have the right propeller?
Depends.
You going to race it?
billyboy
Post by billyboy »
yes... that is the correct prop. there is also a 5-bladed 11" prop that will suit that model. dont know too much about racing myself but i would imagine a smaller and faster prop and gearbox would be more suitable.
Tonyseagull
billyboy wrote:yes... that is the correct prop. there is also a 5-bladed 11" prop that will suit that model. dont know too much about racing myself but i would imagine a smaller and faster prop and gearbox would be more suitable.
Thanks for the info on the propeller...no I won't be racing the Seagull
NUTS!
I thort someone would bite.........
