gasket,s
Re: gasket,s
You are only going to need to replace a gasket once, so best to use the right ones.
Give John a ring at the top of the page, he has all the gaskets you need.
Re: gasket,s
http://www.saving-old-seagulls.co.uk/fo ... f=5&t=2088
Just one for the gearbox. a little satisfying doing your own but the rest are fibre and better buying em from john
Re: gasket,s
THANK,S GUY,S JUST AS I THOUGHT WILL GET FROM JOHN
MANY THANK,S
Re: gasket,s
Find some paper or thin card that is the correct thickness, then just cut them out.
A small set of punches will make it a little easier.
Most if not all seagull gaskets are not very highly stressed, so as long as the paper is the correct thickness then you should have no problem.
