Proposed Guide Topics...
Guest
Post by Guest »
Please post your ideas for topics we should have in The Guide here.
Guest
Re: Proposed Guide Topics...
Post by Guest »
First things first
Guest
Post by Guest »
Maintenance
Guest
Post by Guest »
Winterizing
Guest
Post by Guest »
Appendix
How about a focus on the main things that cause seagulls to be discarded, put at the back of the garage and left to rot? I'm thinking, carbs/tanks full of gunk, points cleaning and setting, water jacket corrosion. Sort of "How to get that ebay bargain going again"
Guest
Post by Guest »
Good idea Oyster... should it probably follow on from the Before you start your Seagull for the first time... post?... 'I've done that and there's no sign of life yet...' :?:
Daryl
Re: Conrod
Post by Daryl »
This is a band new conrod these screws at the end, need checking to see if the are tight & have the locking wire in place.
Daryl
Re: Prop removal
Post by Daryl »
Series of pics to remove prop.
Daryl
Re:Gearbox
Post by Daryl »
Exploded view of Gear box. (if inapropriate please remove) They are out of a very old book.
Daryl
Re: Carbys
Post by Daryl »
Pics of Villiers & Amal carbys.
There should most definitely be a short article about what to do if you come across an early Seagull - say, pre 1942.
There are pitfalls for the unwary, and many of the parts are simply unobtainable. A good example is gearbox front caps in the OAs - the thread is left handed and may be impossible to remove without incurring irreparable damage.
I'll chat to the other Charles about this; I feel it's important that we don't accidentally destroy something historic!
Daryl
Re: CENTURY & CENTURY PLUS
Post by Daryl »
Parts sheet with orig part Nos from 1955. still have that O/B.
Daryl
Re: CRANKCASE BUSHES
Post by Daryl »
Pics of Crankcase bush removal & instaler fabricated by a machinist.
Daryl
Re: GEAR CASE dismantle
Post by Daryl »
More pics of dismantling a Gearcase, thrust washer at end of biro dont loose.In the last pic the collar pin can be removed through slots at front of gear case then remove pinion.
