sick seagull south west!
wassall
Post by wassall »
Hello! ive just bought myself a little boat with a seagull engine. It was serviced in 2008 then stored in a garage until now. I have never had a seagull engine so am unsure what all the levers do! and have also been told by the chap i bought it off that he tried to start it but it wont start. wheres the best place to start? i am good at DIY and with a screw driver but need some guidence! or should i just take it to my local marine place and ask them to get it going?
thanks in advance for any help you can provide! chris
one_riff_brian
Re: sick seagull south west!
Post by one_riff_brian »
The first step needs to be identifying it- can you find the serial number stamped on the crankcase? After that, check the gearbox oil, set it up in a barrel of water and have a shot at starting it. Try to establish what's missing- fuel, compression or spark, and take it from there.
If it moves and it shouldn't, use Gaffa tape.
If it doesn't move and it should, use WD40.
wassall
Post by wassall »
hi, this is the info the chap who was selling it gave
Manufacture Year: 1978-79
Model: Silver Century
Type: Clutch Drive
Power: 3 - 4.5 HP
25:1 oil mix
SAE90 gear oil
Serial number: WSC 1048AA8
wassall
Post by wassall »
Well! Cleaned the on points up, super flooded it and it started right up! These engines amaze me!
Nice looking engine and welcome. we are slowly putting together a beginners guide to seagull ownership on the forum which you will see on the main index page. Theres some usefull stuff in there. It's worth a nose around.
Very nice and original motor Mate!
A bit of cleaning up visually (Good for the Soul) and you can be very proud.
You will never wear it out by the way.
