SD Throttle lever wanted
Post your wanted adds here
Double Dutch
Post by Double Dutch »
I am looking for an original throttle lever for my Seagull SD.
Regards, DD
Holland
Re: SD Throttle lever wanted
Hello DD, best of luck, sorry I havnt got a spare. I had to buy another engine to get the throttle lever I needed!
Some of the early AD's/AC's had them.
I have seen 3 different throttle levers fitted to SD's, which was correct or were they all correct because it didn't matter to the user, I don't know.
But I do know a couple of guys who have quite a lot of them, I will ask them the question.
Should we put a poll up as well? a poll with a usefull purpose might benefit a lot of us.
My camera software won't work with windows 7, can any SD owner with a different throttle lever, post a picture on this thread to illustrate the options for this poll.
The three I have.
Non brass throttle on SD
Later curly throttle on SD??
Naval. Early. No 250
You have a skeletal bracket. I'm jealous!
I have only ever seen the brass long amal lever. Interesting to see that lever fitted to the prototype little 40 in the adverts on the SOS site. Makes me think that that lever was around on other early post war engines too, not just SD?
PAULT50
Post by PAULT50 »
Not on an sd, but someone pointed out that it was an early type.
Jan
Post by Jan »
It's an early Villiers throttle lever as used on Seagulls with Villiers carbs.
Jan
xtaffy2
Post by xtaffy2 »
Theres one here.
http://www.trademe.co.nz/motors/boats-m ... 080052.htm
Exchange rate is just under the $2 to the pound.
Kiss =Keep it simple stupid
Slightly off topic but searched that NZ site and found.................
http://www.trademe.co.nz/motors/boats-m ... 302003.htm
xtaffy2
Post by xtaffy2 »
Sorry about that being off subject, i was looking at the throttle lever, a straight one. My Sd is the bent up on the end type and that's a 45/6 vintage and i thought the straight ones were from earlier units.
