New SD project
Niander101
New SD project
Post by Niander101 »
Degreased for a start
drive shaft has been put in box wrong way round!
Re: New SD project
Excellent base for a restoration, seems complete. Whats the number? I can I register it? Could that be an original trumpet? 8) Not many of those about.
Niander101
Re: New SD project
Yep it came with it
will be original
genraly looks in great cond has been protected by paint..:)
a mega long tiller on it
short shaft with clutch
SD 1823P3
add it
skyetoyman
Re: New SD project
Post by skyetoyman »
looking like a good one. wrong transom bracket but a good tank.
Best of luck
Niander101
Re: New SD project
Yep but it will do for my next century plus! :P
Re: New SD project
Is that a brass or steel tank, need to log all the facts. Can I have the JM number at some point?
That makes 8 engines on the list, slowly making progress :P
Re: New SD project
Nice steel tank, of the type with the rim around the edges. Fewer of this type of tank around, I suspect. Nice carb and air intake, and what looks like the original tank support lugs.
I do like these in nice original condition. Well found!
Re: New SD project
Nice one, should be an easy restoration.
I do like engines that have been painted, I find they are often nice under the paint.
Niander101
Re: New SD project
NIce easy ebay find
i can feel play in the main bearing will need sorting
Re: New SD project
A good, honest looking SD!
Niander101
Re: New SD project
Yes im pleased with it
would the fuel pipe been bent like that originally?
also are there any ignition units like this available?
i need one for another motor
Niander101
Re: New SD project
JM 12269
Re: New SD project
Got it Thanks!
Re: New SD project
The fuel pipe is close to the shape it would have been when new.
Ignitions are available but at a price, for one with a JM number that goes with the serial number & isn't on it's last legs you might have to pay as much as you paid for the whole motor.
Your new SD didn't leave Seagull with that ignition on it, are the JM numbers on the flywheel & the base plate both the same?
Niander101
Re: New SD project
I need to get a flywheel puller off John
where abouts on base plate are they?
i dont care about correct JM numbers but the correct parts i am
